Need Help!
Old Mar 27, 2001 | 08:41 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Need Help!
yesterday i replaced the coolant temperature sensor. I had to take off the TB and some wires..put it all back. When i tried to start it it wouldnt hold an idle. I thought i messed up and had a vacuum leak..took it off and nope no leak.
I checked codes and got a 34 for MAF..went and got a new one. Still the same. If u dont unplug the MAF it wont idle. If you do, it will somewhat with the idle going from 400 to 1200 then back down. It will at least run. What the hell? I need ideas...BTW its running a code 34
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
[This message has been edited by Graeme'sFirebird (edited March 27, 2001).]
Old Mar 27, 2001 | 11:02 PM
Vader's Avatar
Graeme,
Clear the codes and reinitialize the ECm, then try again. If the old CTS was indeed bad, teh ECM will have to "learn" the new one and the correct values all over again, so it can write the new fuel and spark tabels correctly with the new sensor input.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 27, 2001 | 11:48 PM
OK ill try it out...hopefully thats it! If not i dunno...what exactly is code 32 also??
1989 Firebird
Old Mar 28, 2001 | 12:08 AM
Vader..that didnt work. Still fires and dies right away
1989 Firebird
