M55 Oil Pump
Old May 26, 2004 | 03:32 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
M55 Oil Pump
The M55 comes with the pink spring, should I remove this spring and installed the Mr. Gasket #26 Spring. What is the Pressure difference between the two springs?
Old May 26, 2004 | 03:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Approximately 35-40 psi hot cruising to 50-55 psi hot cruising
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
