how do you fire up a new engine ??
i got a 355. accel distributor, performer RPM intake holley 750, comp cam, and a couple of other things this past week and im pulling out my motor when it gets a little warmer in a day or 2 here hoppefully and i was wondering if there was a specific way to fire up a new motor ?
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Maybe I am just paranoid, but, when firing a fresh motor, first I prime the oil pump. (I have the neat little tool for this, goes down the dist. shaft) Build as much pressure as my electric drill can manage, fire the engine and let it idle at about 1500 RPM for about 30 minutes. (this is generally to break in the cam, etc.) Shut down, change the oil, drive it for 500 miles, change the oil again. I have had great success with this process, now have 140,000 miles on rebuild......
Have fun.
Have fun.
91,
Here is a GMPP recommended procedure:
Break In.pdf
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Break In.pdf
Later,
Vader
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Do you have to do this with new cars?
If not, why?
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
If not, why?
Zepher
WS6 Trans Am
eightsixseven
Dec 16, 2024 01:50 PM
