Holley egr block-off plate
Old May 26, 2004 | 09:05 PM
25THRSS's Avatar
Anyone have any pics of this product?
http://www.jegs.com/cgi-bin/ncommerc...27&prmenbr=361
If you know of any other egr block-off plates out there let me know.
Old May 31, 2004 | 10:01 AM
Vader's Avatar
Edelbrock also has them. Sorry, I don't have a part number:
Old May 31, 2004 | 12:51 PM
Damon's Avatar
Vader's attached image is actually of the choke heater block off which also serves as a mounting point for an old style divorced choke element.
An EGR blockoff is flat metal shaped just like an EGR valve gasket but is solid metal with no holes in it. Sorta triangular shaped, held in place by 2 bolts just like the EGR valve would be. Look at the mating surface of an EGR valve and imagine a solid piece of metal shaped just like it and you've got the basic idea. Yes, you still need to use an EGR gasket underneath it to seal it up or a large vacuum/exhaust leak will result.
Old May 31, 2004 | 01:57 PM
Vader's Avatar
You're right - Good catch! That's a choke block-off. I was confusing it with the last carbed engine I worked on. That is CLOSE to the EGR location on an '81 L82. I'm trying really hard to forget about three decades of carburetors.
Old May 31, 2004 | 09:22 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
now i wish i had some pics of the last 3 egr block off plates i made .....lol..all you need is a piece of steel and a cut of wheel or good ban saw and a drill go get a gasket use your old bolts and you have one for virtually nothing if you have any scrap laying around ...then just put a good coat of spray bomb paint on it and bam !! your done..LOL....its not that hard and ive never had aproblem with one yet
Old Aug 5, 2004 | 01:05 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
I have a question. What do u do with the connector so that u dont keep getting the code thrown at u?
Sparrow
Old Aug 5, 2004 | 02:15 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Duck!
Old Aug 5, 2004 | 09:59 PM
25THRSS's Avatar
plug the vaccum lines and delete the egr from the chip
Old Aug 6, 2004 | 01:29 AM
lbrohez's Avatar
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
i made one from a piece of 3/8 aluminum and a hacksaw, a bench grinder, and a hand drill.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Kenwood
Sep 11, 2015 12:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
