Check out this 406 Crate Engine !!
Old Mar 24, 2001 | 01:07 PM
BigBlockJason's Avatar
Car: 1985 Z28
Engine: 502
Let me know what you guys think of this motor with the two options installed. I think it could be close to 500 Hp, what do you guys think??
http://www.allchevyengines.com/406-435.htm
BigBlockJason
85 Z28 T-Tops
http://communities.msn.com/JasonsStuff/homepage
Old Mar 24, 2001 | 02:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The short block looks pretty much OK; I assume those heads are 74 or 76cc to give that CR... I'd sure put some other cam in it though. Maybe a Comp XE274H and 1.6 roller rockers. The valve springs might need some attention from doing that. I believe I'd also lose the HV oil pump, put a M55A or a M55 with the Mr G #26 spring in it.
The options are very cool.
ICON Motorsports
[This message has been edited by RB83L69 (edited March 24, 2001).]
Old Mar 25, 2001 | 02:43 AM
Car: 1985 Z28
Engine: 502
Anybody else?
Old Mar 25, 2001 | 11:44 AM
Z28DJP1987's Avatar
406 crate engine a assemlby you may buy, and the comment was " change the cam, the springs
and etc." A good buy, and comments be D---
go for it. Remember, its a brand new engine
and not a work in progress.
Old Mar 25, 2001 | 03:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Just because it's a "crate engine" doesn't necessarily mean it only comes like the web page says. This isn't GM where they build millions of identical ones on an assembly line, it's more like Burger King, so when you order it, have them build it your way instead of the generic way. I'm not suggesting you tear it down and change it yourself, voiding the warranty, since about the only advantage there is to buying a "crate engine" is the warranty.
It's a decent enough basic combo as it is, but with some very minor, near-zero-cost changes, it can be made much better. For what the changes I suggested will cost, they're alot more bang for the buck than the head & roller upgrades, since they'll give you easily 40 more HP for what should be less than $250 additional.
ICON Motorsports
Old Mar 25, 2001 | 04:09 PM
Car: 1985 Z28
Engine: 502
Good point, but I wouldnt even consider the motor without the two options included. That would put me about right where I want to be price wise anyway. I think that changing the cam would be a good idea also. Seems a little small for a 406. Eventually i want to run a miniram of this thing too, I think it should scream. My only concern would be the quality of the work done at that place. I would be comfortable with Sallee, or Scoggin, but I havent heard anything about this place yet. Anyone have any expierience with this place?
BigBlockJason
85 Z28 T-Tops
Old Mar 25, 2001 | 05:46 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
i highly doubt that thing would be 500 hp in that form. with options listed, easy. 750 bucks for a roller, holy crap. i would imagine that comes with the springs, lifters, cam, and pushrods. seems like a lot of cash for a roller, but all of the components separate would probably be the same price. that is why i went with the ancient tech flat tappet in mine, $150, hehe.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
Dart equipped 406
12.20 @ 115.25 mph
Old Mar 25, 2001 | 07:01 PM
Z28DJP1987's Avatar
I have a 350 from ALL CHEVY ENGINES, and have no problem with their workmanship or parts used. One year warranty with unlimited mileage. Give them a call.
Old Mar 25, 2001 | 08:29 PM
84FTA's Avatar
Any of you notice the small *** valves? 2.02/1.60, I can put than a 4.000 bore much less a 4.125 bore.
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Mar 26, 2001 | 09:21 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
well that's not bad but i would think you could do better. Get them to give you a quote on just a shortblock with no cam (anything that is 500 and 292 is old and probably sucks). Get a hydroller (500 cam/lifters is about right) and another 200 for pushrods and rockers. You can get the new pro1 dart heads for about 575 each complete and they do move more air than the Sportsman IIs. It will be very close to 500hp with something like that. I would be prepared to spend 4500 without carb and ignition
I have right about 1800 in my 400 shortblock (not counting cam) PS, that is with new 4130 I beam capscrew rods and SRP pistons.
[This message has been edited by jcb999 (edited March 26, 2001).]
Old Mar 26, 2001 | 09:49 AM
Z28DJP1987's Avatar
In conculsion to this post on a 406 crate engines,I have two suggestions.
1) Performance engines 101
2) A Summit catolog
Now go bulid it, and it shall run fast.
Old Mar 26, 2001 | 09:58 AM
buddman91rs's Avatar
has anyone seen the add in car craft for a blown 540? makes like 900hp.....price blows it out of the water though...$9,999 geesh
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
GONE MUSTANG HUNTING.......
BACK IN 10 SECONDS
Old Mar 26, 2001 | 01:50 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Just bought the 350ci/360hp model from All
Chevy Engines. In the process of installing
now(replacing the L69). Anyone else have any
input on this engine builder or their products ?
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Old Mar 28, 2001 | 11:04 AM
Car: 1985 Z28
Engine: 502
Anyone else?
Old Mar 28, 2001 | 02:23 PM
offroader's Avatar
Cast crank seems a little weak for my tastes. I would have gone to a forged crank and a better set of rods. At least Eagle I-beams. But for a street engine and no N2O, it will work.
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
