Benefits of 305 heads on a 350
Old Mar 28, 2001 | 08:10 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Are there any benefits with 305 heads on a 350?
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 28, 2001 | 08:46 PM
illegal87's Avatar
Smaller combustion chamber on 305. Means more compression. BUT! way smaller valves. You will need to find out if 305 heads can be cut to accept 350 valve seats. Late model 350 intake valve is 1.90.
Old Mar 28, 2001 | 11:31 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
They can be cut for the 1.94 intake valves but the chamber has to be unshrouded for it. I would use 305 heads on a 350 mainly because if they are stock, even mildy ported they don't breath above 4500 RPM's on a 305, it would be even worse on a 350 with the bigger pistone size. The comp would be great but again the loss at high RPM IMO is not worth the low end gains. If you are dead set on the high compression, i would either get your heads milled to 60cc or get the SR 305 heads. just my .02 cents
Laters
89 RS Conv 305 700R4
85HO heads
Edelbrock intake
Holley 600
Hedman Hedders and Y pipe
Flowmaster
B&M MegaShifter
[This message has been edited by Chvywolf (edited March 28, 2001).]
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
