Gear Question
Old Mar 28, 2001 | 01:47 AM
Ovrclck350's Avatar
Gear Question
I can get a set of 3.23's from a 98 Z28 for $75. My question is, will these gears fit in my 92? I want to buy them, because (correct me if I'm wrong please) it will then be limited slip. However, if they're not going to fit, or if it won't be limited slip, I don't want to waste the money.
Old Mar 28, 2001 | 06:15 AM
Baz89RS's Avatar
The gears will fit but the gears themselfs are not limited-slip or posi's... It's the differential that can be limited or posi. So unless your buying the gears with the differential included it won't be.
Old Mar 28, 2001 | 11:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You have a 92 what? If your 92 has 2.73 or 3.08 gears now, then no, 3.23's wont bolt in. You will need a 3-series posi unit to use those gears. You can get one for $99 from www.slponline.com , its called their take-off torsen posi. Dont forget you'll have to change your speedo gears in your transmissions for the new rear gears.
That will give you the gears you want, plus a posi unit so both tires spin.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
