TPI module probs? Need help
Old May 29, 2004 | 05:51 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
I am having a problem with no starts. I swapped in TPI and had it since January. Within the last 3 months I have been having problems with my ignition parts.
First I blew a pickup coil.
Then I blew out the module.
Since the first module went out I have been having the problems. The first module was a Delco. The replacements have been Borg Warner parts.
About once every 3 weeks (or less) my truck won't start. If I change the module it starts up just fine. The wierd part is if I leave the truck alone for a few hours and don't change the module it usually starts. WTF?
Today I tired changing the EST and the ECM before I replaced the module. Niether worked. Thanks
I am running '88 MAF TPI in my 85 GMC Jimmy. Its ignition is stock. MSD 8.5 wires, MSD cap & rotor, painless wiring harness.
Harley
Old May 29, 2004 | 10:21 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Are you using any heatsink compound between the module and the distrib base? Not using any would kill them as fast as your describe.
Old May 29, 2004 | 11:05 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Most of the times I have used the supplied opaque white Dielectric grease that comes with the module. I have also used a tube of the clear dielectric grease I picked up from Autozone. Every module has had the grease of one form or the other under it.
Harley
Old May 30, 2004 | 11:47 AM
Vader's Avatar
What ignition coil are you using?
What is the normal system voltage with the engine warmed and running?
Old May 30, 2004 | 05:01 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Stock external coil and my alternator charges at about 13.7 or so I believe. I have to stock coils and I have switched them and it does the module thing with both coils.
Old Jun 1, 2004 | 08:23 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
TTT?
Old Jun 2, 2004 | 10:49 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Nobody can help me out here? Someone has got to have some insite............
84z96L31vortec
Aug 20, 2017 12:16 AM
stalkier
Dec 6, 2015 11:25 PM
Bryan F
Aug 27, 2015 07:28 AM
crazynights
Aug 21, 2015 06:53 AM
Sanjay
Aug 12, 2015 03:41 PM
