Radiator and spark plug questions...
Old Mar 29, 2001 | 03:17 PM
kamac's Avatar
Car: 1989 Firebird
Engine: 2.8 MPFI
Anyone else have problems with the plastic side tanks on the radiator cracking? Is there a reasonably priced alterative? I ask because at the moment my radiator is being replaced. Also I am having a lower temp thermostat put in (180-190). Is there any need to go with a different temperature spark plug? This is something a mechanic suggested. Thanks for the help.
1989 Firebird 2.8L MPFI
K&N filter w/modified airbox
Flowmaster 2.5in Cat-back
Accel Cap, rotor, coil, 8mm wires, Rapidfires
Energy Suspension bushings
Edlebrock springs
Bilstien Shocks & Struts
Shift Kit
265/50-15's on stock rims (really)
Lots of TLC
Old Mar 29, 2001 | 03:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Radiators are a maintenance item. The brass/copper kind are a little more durable but weigh a whole lot more.
There's no particular reason to change spark plug heat range because the coolant temp is leing lowered. If the car has a tendency to ping or run on, cooler plugs can help; other than that, just use what the book calls for and you'll be fine.
ICON Motorsports
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
