A few MSD kinks
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
A few MSD kinks
I just put in my MSD and coil and it wants to almost die at random [not too often] like it not getting fuel or something kinda breif.. I know it's not Fuel (Good Pressure) but I thought it might be plug gap or something.. it's still at .035 and I'm still using 7mm "stock replacemet" but new wires
I was running it pretty hard the night before also but nothing happened then
anybody have any ideas on what might be making the motor "choke" like that at random????
THANKS
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel & Oil Press Guage's
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
THANKS
Hecubus
Car: 91 z82
Engine: 5.0
I took care of that problem
I just wanted to say thanks again for the help
Dose anyone know what Gap I should set plugs at now???
also how important is it that I go to an 8.8mm wire??? (or something close to that)
Hecubus
Hecubus
if you have a good strong coil i would bring that gap up to .045. and as for the 8.8 wires, its all insulation. your getting more protection from heat and crossfire with the bigger wires.
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
