Replacing a Fuel Filter
Old Jun 3, 2004 | 09:14 PM
berklified's Avatar
I have an '82 Camaro, with an '87 5.7L 350 dropped into it. She's running an Edelbrock 650cfm carb. I recently picked up a new fuel filter from Canadian Tire. It's a simple in-line filter. The one I picked up seems to be a little larger then my old one, not a problem right? My real question is how do I change them, without getting fuel everywhere? I assume clamp the lines and then replace? is that right? Need help!
Berkley
Old Jun 3, 2004 | 09:37 PM
Iroc n roll's Avatar
Before you touch any portion of your fuel system you have to relieve the pressure. This can be done at the schrader valve on your fuel rails if you have the tool or more commonly by removing your fuel pump fuse and cranking the motor until it stalls and giving it another one or two cranks after that for good measure. Fuel will still drop out some when you disconnect the lines so have a catch can, some rags, and a fire extinguisher nearby. Yes I know it sounds overkill and you probably won't need it but even static electricity can set off gasoline so its best to be safe than sorry. Hope this was of some help and good luck.
Old Jun 3, 2004 | 09:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can also take the gas cap off. However, the fuel in the lines will still leak out a bit but at least it wont shoot out at you.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
