could this be a bad sign??
Old Mar 30, 2001 | 04:50 PM
AirN1's Avatar
my dipstick tube for the oil is really really loose....i can wiggle it all around....can the be a potential bad thing....like for and iol leak or something.....and how can i fix it???
Old Mar 30, 2001 | 05:02 PM
Macgyver's Avatar
It could leak, but probably not, crud builds up around it over the years and kinda stops the leaks.
Just push down on it while wiggling it, if it slides down, grab some bailing wire and wire it still, if it doesn't go down, wire it anyway.
Old Mar 30, 2001 | 07:04 PM
Kyle F's Avatar
MIne is lose to and has been since 98, no leaks. What has happen most likely is that your bracket that holds the dipstick to the header to prevent it from moving. Well my bracket didn't like the way my headers curved so I had to leave it lose, and no problems with it coming out or anything.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil,MSD Wires, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added.
Stereo has 2 Clairion Pro Audio dash plates, 2 Sony 6X9s, 2 Kicker 12's in a custom Carpeted box with a custom amp rack Holding 3 MTX 280 Amps, and a MTX electronic Crossover all wired with EFX cable.
Asking $4200 with all extra Parts that are needed to fix most apearance flaws. ie Complete hatch and wing from a 91 GTA
http://geocities.com/feltsb/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/2 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Old Mar 31, 2001 | 09:14 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Heh, mines broke, it got broke putting the headers on. One day I'll replace it, until then, I don't know exactly how much oil I have in it. I believe it screws in, try twisting it right, if not, it shoudln't be expensive to replace
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
Old Apr 1, 2001 | 12:42 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
It's just a slip fit. Lokar has a really cool flexible tube if you have hedders. Until I got this tube, I just plugged the hole with an orange wire screw and some silicone.
If it's loose from the block (not the manifold bolt) try adding a rubber o-ring and coat the o-ring with some silicone. If you're not losing oil I wouldn;t worry too much about it.
Abubaca
Nov 5, 2016 12:22 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
Racerx974
Sep 19, 2015 10:16 AM
gta892000
Sep 16, 2015 12:40 AM
