ECM
Old Mar 31, 2001 | 01:10 PM
4SPEED's Avatar
ECM
THIS ONE IS WIERD AND WOULD LIKE TO KNOW IF THIS IS NORMAL...WITH A 700R4, APPROACHING A STOP AND YOU DOWN SHIFT INTO 2ND GEAR, WHEN THE TACH REACHES 1000RPM THE ENGINE WILL SURGE UP TO 1500RPM AND THEN DROP TO NORMAL IDLE BY THE TIME YOU COME TO A COMPLETE STOP...ANY IDEAS?
Old Mar 31, 2001 | 05:54 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
my friends did this in his 86 IROC and we figured it to be a vacuum leak possible intake gasket or broken vacuum line
Old Apr 1, 2001 | 01:33 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Some aftermarket trans do this all the time. Most 700's i'd driven do this coming to a quick stop in 3rd. I'm not sure if it's the b fix kit or blocking the line bias valve in the trans.... It's normal in some cases, but in OD only in special cases..... No worry either way imo...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
