Solid Roller Lifters
Old Jun 4, 2004 | 08:15 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I've seen several references to using solider roller lifters on a hydraulic roller cam.
The cam manufacturers don't rec it, but it can be done. They say you have to maintain a very tight lash for all to be well.
Anyone else heard of this or heard of anyone trying it?
Thoughts?
Old Jun 4, 2004 | 08:30 PM
ede's Avatar
ede
you have to match the lifters to the cam. running solids on a hydrolic can be done since the lifters all fit the same hole, the big question is how long are you willing to run it before you have to replace the cam.
Old Jun 4, 2004 | 08:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Never done it on a roller, but I've done it with flat tappets. In case of dire need.... like a semi-emergency when I had some random cam and a set of solid lifters and I had to get a motor to run, and it turned out that the cam was a hydraulic.
The lash wanted to be down around .008" or .010".
Yes it works. But not near as well as the right cam with the right lifters.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
