How do y'all have your spark plug wires ran?
Old Mar 31, 2001 | 11:31 PM
LottaBallsCamaro's Avatar
on my passenger side three of them are ran around a heater hose, that cant be good for tem...
We are the future, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Apr 1, 2001 | 12:09 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
A heater hose will never get hot enough to cause you a prob. With manifolds, it seems, getting longer wires and going under them works. With hedders some kind of aftermarket wire ties... 'made for you' seems hot, but I have good luck with R&M mounting them staggered... The bolts are hard to get at, but once you clamp them down where you want them, they will stay away from the heat. Manifolds are the only thing I would seriously worry about. Heater lines are only around 220 degrees. They could even rest on them and i wouldn't worry. Manifolds/hedders are the ultimate wire killers.
You also don't want to run your wires in long lengths together such as zip tying them all together. it may cause a mis-fire if using substandard wires (spiral is the best for most apps)
Hope it helps...
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Apr 1, 2001 | 06:21 AM
ede's Avatar
ede
if you're worried about heat on your wires there are several differant insulating sleeves made for them, plus wire seperators. the headers are what you really want to watch out for.
ICON Motorsports
1st & 3rd
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
