Valve stem seals
Valve stem seals
My valve covers were suppose to be fixed be my dad's mechanic but he just barely looked at it and also didnt change the brakes wrong.....Well my car is smoking alot now because it had been stopped for a year...How hard is it to change the valve covers and the valve stem seals???Where can i buy the seals(can anyone give me a list of stuff i will need to buy from jegs or summit).....Also can i do it myself?
1988 Trans am.......best 600 bucks ive ever spent...305 5.0 but will save my lunch money and every penny to swap for a 350 tpi in the coming two years
not hrd to change if you have a little mechanical talent. you can buy the gaskets and seals anywhere. i use the o ring and the unbrella seal both. you'll need the common hand tools, plus a valve spring compressor to remove springs on the engine and a air compressor and fitting to keep air in the cylinder while you change the seals.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
felpro makes a "viton" valve seal that works great. it holds up under extremes, but they are a real pain to install. much harder to get down the stem than factory type.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
355tpipickup
Sep 13, 2015 11:35 PM
