Can someone Please help me with Distrubtor Pick up coil testing
Old Apr 1, 2001 | 03:19 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Well in past post We've concluded that it has to be the distributor that has gone bad....
I'm having troubble with testing it to see ... first of all it LOOKS pretty dang rough kinda rusty and when I turn the housing it's pretty rough and kinda gritty sounding
second I've tested the OHMS and it's about 500-600 but the article that I read said that if it changs at all when you move the pickup wires that it need's to be replaced....well it dose it changes about 100 most of the time but I cant really tell if it's that or I'm loosing connection to the pick up wires ... but it seems to be changing
and last it also says to check it with one lead in the pick up and the other to a "ground" I did this and nothing happens at all... it says that it should be Infinity
is there any better whay to check this ......also how likely is it that the Ign. moduel might be bad ((last post I was explained that I am not getting spark with new coil plugs cap rotor wires))
what do you make of that???
somehting else that I can do to check it??
ANY info would help
Thanks!!
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Apr 1, 2001 | 08:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
PU Coil should be 800 ohms, +/- 25 ohms, and not change when the wire are wiggled.
Of you see crust in it, get a new one. Sure sounds like yours is bad.
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
mddaniel
Sep 8, 2015 05:16 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
