How bad is this?
Old Jun 6, 2004 | 01:17 PM
dp149's Avatar
How bad is this?
I was given this 305 for free. Took off the heads and this is what I saw...could this have been from a blown head gasket? or is the block/cylinder head cracked...?...
Any advice would be helpful...this was going to be a low budget rebuild but now i am worried I am looking at replacing many parts....
Old Jun 6, 2004 | 01:34 PM
ljnowell's Avatar
Well, thats definately not very good. Could be a bad head too. If you are dead set on rebuilding a 305, take it apart and have it checked by a machine shop. Thats the best way to go, it could probably use a little resizing of the bores too. It certainly doesnt appear to be a low mile engine.
Old Jun 6, 2004 | 01:58 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
question why rebuild a 305 when for pretty much the same money you could rebuild a 350
Old Jun 6, 2004 | 04:29 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: How bad is this?
And now you have the second reason it was free. The first was because it was a 305. Really.
As for how bad that is, depends on how bad the rust is on the cylinder wall. It may be toast.
Old Jun 6, 2004 | 06:28 PM
dp149's Avatar
Thanks for all the replies...I am rebuilding a 305 because I already have much of the 305 parts and short on $. I was hoping the block would come out ok from this one so I could put my good internals into it..
The rust on the cylinder wall isn't awful but obviously not good. Is there anything I can do to check the block and/or cylinder head to determine which was the problem? or am I forced to take it to a machine shop? Like I said, short on $ so if I don't have to, I don't want to...I was going to just remove all the internals and degrease it like crazy and then check for any obvious cracks...unless everyone thinks that is a waste of time at this point...
any other advice would be helpful...
Thanks Alot....
Old Jun 6, 2004 | 06:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
If the rust is more than just the light surface rust, I wouldn't bother. Most of what you are going to use on the 305 can be used in the 350. I think ede had posted a while back the nuts and bolts of that discussion. Try a search. What parts do you have that you are going to use on the new engine?
Old Jun 6, 2004 | 06:36 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Most likely it will need machine work to repair the damage, so junk it.
If your looking at making a little more power cheap, head to the junkyard and find a 350 junkyard jewel and re-ring it. Look for cars that were wrecked because of an accident. Pull the heads and look for any damage and a cylinder ridge. Then pull the pan and look for damage or metal in the oil. If there isn't any damage to the engine, you might have a pretty good engine that will run good if you replace all the bearings and re-ring it.
This is not the proper way to do build a reliable engine that will last along time, but it is cheap.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
