How do I tighten the throttle cable?
Old Mar 29, 2001 | 09:32 AM
Camaro_84's Avatar
My car is a little laggy, I think the throttle cable might be getting lose from age, how do I tighten it? If you have pictures or anything, it would be appreciated.
Old Mar 29, 2001 | 12:09 PM
84TransAm's Avatar
You can't tighten it. If it is loose due to age, you have to replace it. It's pretty straightforward. Remove cable from carb (if applicable) Then remove panel underhang thingy from below dash, above your feet when driving. Then lay on the seat on your back with your head by the pedal. This allows easy and comfortable (relatively) access to the pedal. Then you unhook the cable from the pedal, go to the firewall and use a crowbar to disconnect it from the firewall.
The cable itself is about $14.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Old Apr 1, 2001 | 09:50 PM
Camaro_84's Avatar
I've worked on 300ZXs and you can tighten the throttle cable on them reletively easily. Along with Supras. I was told that you can tighten 90% of throttle cables, so why is it different for camaros?
Old Apr 1, 2001 | 10:03 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Most american vehicles don't have provisions for adjusting the throttle cable. Many foreign vehicles do. No idea why. I don't feel the need for adjustability on my throttle cable. Basically, if things are bad enough that it needs adjusted, I'd want to replace it anyway, because it has probably streched.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 2, 2001 | 02:10 AM
burnoutrpm's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 84TransAm:
</font>
im with this guy... you dont adjust a american 3rd gen t. cable!!! you just replace it!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
