Need guide plate w/World S/R Torquers ?
Old Apr 1, 2001 | 07:52 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
I was thinking of installing roller rockers
on my new crate motor before doing the motor
swap. Do I need guide plates if I use non-
self aligning rocker arms? S/R Torquer heads
are like older chevy heads that have small
oval shaped holes for the push rods that are
fairly tight clearenced. Thanks......
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Old Apr 1, 2001 | 08:31 PM
89BlwnRs's Avatar
Yes, if you're not using self-aligning rockers then you need guideplates.
Jason
Old Apr 1, 2001 | 11:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the heads have slots that locate the push rods with less than about .015" or so of clearance, then you don't need guid plates or SA rockers.
There needs to be one AND ONLY ONE method of establishing rockerr alignlment, out of 3 choices: slots, guide plates, or SA rockers. Any of them works OK, just pick the one most suited to your application. If you have more than one of these things, you will probably have them fighting each other, and something will be in a bind.
ICON Motorsports
Old Apr 2, 2001 | 07:44 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Thanks RB, I was looking for some kind of
number. I'll measure it up tonight.
Thanks again......
Tom K.
Old Apr 2, 2001 | 11:58 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
I went home for lunch and they measured
.012" total clearance.
Tom K.
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
