Vortec heads question
Old Jun 7, 2004 | 04:12 PM
M85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 305, soon to be 350
Hi, im currently building a 350 for my camaro. I have an 87 350 engine and i already have the new replacement gaskets. My question is can i use the same head gaskets if i want to put on some recent Vortec heads?
Old Jun 7, 2004 | 04:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think the answer is "no", but I'm not sure so I'm moving it over to the Tech board for responses.
Old Jun 7, 2004 | 10:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I think you can. I dont think the head gaskets are specific to the Vortec heads like the intake gaskets are.
Old Jun 7, 2004 | 10:29 PM
87Formula4bbl's Avatar
Car: '87 Formula
I don't see why you coudln't...Intake gaskets are a different story.
Old Jun 7, 2004 | 10:30 PM
AKL98's Avatar
Car: 91 Z28 L98
Engine: 350 5.7l TPI
Transmission: 700RT
I just build a 355 with vortec heads, and I used a FelPro gasket set - I had to get vortec intake gaskets but the headgasket fit fine, adn I've had no problems with it.
Old Jun 7, 2004 | 11:23 PM
five7kid's Avatar
I was thinking the difference in chamber shape might call for a different head gasket, but, what do I know...
Old Jun 7, 2004 | 11:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
More than me...in a lot of aspects.
It might though. Like i said, i am unsure. I have heard of a Gen II SBC HG being used. But i also know of many who have gotten away with running the standard Gen I sbc HG. I guess i would like to see the difference between a Vortec head gasket and a SBC head gasket, if any difference actually exists.
Old Jun 8, 2004 | 12:12 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The chamber does not extend past the cylinder bore, so regular heads gaskets work. Infact any SBC head gasket for a 4.0" bore will work, except of course LT1 and LS1 derivatives.
Old Jun 8, 2004 | 12:12 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
They WILL work fine. I have my vortecs bolted on with the stock rebuild gasket set for a 1990 L98. The bottom of the head surface is identical to older heads (L98 and 87-up heads). I have the GM intake gaskets(which I highly recommend ) which can be used for the life of the engine and they have special silicone rings around each port for a good seal and they lock in place with factory tabs that go into those little holes by the intake bolt holes.
Old Jun 8, 2004 | 12:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if they would have worked for the other heads (meaning they're the right bore size) they could work for this one.
you just need to know the thickness... vortec heads have a smaller chamber, so they'll raise the compression... as long as its still reasonable with thoes gaskets, it'll work.
Old Jun 8, 2004 | 12:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
62cc's vs 64cc's, hardly anything to worry about! The vortecs have an excellent fastburn chamber. So it is possible to run 10.0:1 compression with the proper quench on 87 octane without detonation. You just have to remember that vortec require less timing advance for make optimum power 28-30*.
Old Jun 10, 2004 | 09:24 PM
M85Iroc-Z's Avatar
Car: 85 Iroc-Z
thanks guys, i appreciate all your responses..Now i cant wait to get this engine in the car. Hopefully next week it will be running
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
