Question about air/vacuum leaks
Old Jun 7, 2004 | 05:25 PM
vampiroc's Avatar
Car: Z28
I've always been curious to know if an air leak around an intake manifold or carburetor gasket could cause the engine to run leaner and cause overheating issues. now I know unmetered air can cause idle problems and so forth with any engine but I've never correlated it to some problems I've encountered on cars I've worked on. is it feasible to conclude that an air leak is responsible for a car running hot and searching for idle?
Old Jun 7, 2004 | 06:19 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
A vacuum leak will definatly cause the car to run leaner. While lean mixtures do create higher combustion temperatures, that doesnt necessary mean your engine temperature will be hotter. I guess theoretically it is possible for a lean condition to cause a car to overheat, it is unlikly. Ive never heard of it happening.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
