Strange Shaking
Old Jun 8, 2004 | 02:31 AM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Strange Shaking
I have a car problem, obviously. Whenever I'm going say 45 mph or less, let off the pedal, and then press the gas down about half way, my car shakes violently until i let off the gas, or punch it to the floor causing it to downshift. Please help me!
btw, how do you set the timing on an enging w/o timing marks?
thanks again
Old Jun 8, 2004 | 02:46 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is it only under those conditions of lifting the foot off the gasm then depressing it 1/2 way again under 45 mph?
Timing cannot be set w/o a timing tab. Well, it can be set by ear, but to accuratly set it you need a tab or some form of TDC indicator with marks showing BTDC.
Old Jun 8, 2004 | 10:31 AM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
pretty much just accelerating, letting off the gas, and then pressing on it again. It's horrible going behind a semi on the highway. speed up, coast, speed up, shake horribly
yeah thats what i thought, i was just hoping for some new way none of us knew yet to set the timing. we've been trying to do it by ear but so far we're unsuccessful
Old Jun 8, 2004 | 06:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
When you nail it, does the engine make a sound that sounds like bits of gravel being shaken in a glass jar? If it does, then the engine is knocking, and your timing is off.
Old Jun 7, 2006 | 08:27 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
does it shake when its in park and u give it the gas? if it is u have a cylinder missing
Old Jun 7, 2006 | 09:10 PM
puffcat's Avatar
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Transmission: manual
Axle/Gears: posi
What motor do you have and how do you not have the timining tab? Ya sure it's not painted over or something? I assume you have an automatic? And does it only do this while actually moving or will it also do it parked? (If you test that, don't have your foot on the brake if you got an auto=bye bye tranny). My first guess would be you're being robbed of combustion, air or fuel. How's your gas mileage? Horrible below normal standards?
Another thing it could be, if it only happens at that speed, might be your cat. But I'm almost sure this is al related to timing.
Old Jun 7, 2006 | 09:19 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
We don't have to worry about this problem anymore. I pulled the engine about 2 months ago. I'm in the process of "restoring." I cleaned out everything from under the hood, fixed a rust hole and i'm currently waiting on money for paint. The car is white but I'm going to get it painted candy apple red so I'm painting under the hood before dropping a 327 with 2.02 double hump heads in it in place of that crap 305.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
BWilcox
Sep 20, 2015 12:19 PM
