Removing ECM - What all is required?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Okay I have decided to ditch the computer this summer. I no longer have to worry about inspection because my bud works at an inspection shop. Anyways, heres what I know I need right now.
1.) New Carb
2.) Vacuum advance distributor
3.) Remove smog crap
4.) Headers
5.) Torque converter lockup switch (inside car, maybe on shifter)
Thats about all I can think of that I need. Any special tools? Also, how do I Actually remove or disconnect the ECM? I dont want a check engine light glaring at me forever...
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
1.) New Carb
4.) Headers
LG4-Based Chevy 400
700R4 Tansmission
3.23 Posi Rear
100WX2 Amp
Car: 1985 Trans Am
7mm socket for the 3 passenger side hush panel screws, then remove the two 7mm screws that hold the ECM carriage, and it will drop down. Use a flat tip screwdriver to pry up the little steel clips on the ECM connectors, and it's done. Just make sure you don't pull on the wires when pulling the connectors out.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Kevin Irving
