CODE 32! what to do?
Old Jun 9, 2004 | 12:21 AM
C_A-Formula350's Avatar
Car: 1991 Formula 350
I ahve been having a bit of troubles with my 91 formula350 lately. Recently i blew a head gasket and with that i replaced the timing chain, water pump, cap, rotor, plugs, wires, Knock sensor, electronic spark module, oxygen sensor, egr valve, and replaced the drusty olf vacume lines. well after all of this my poor car still runs like poo! It seems to have a missing/falls on its face at about 3000rpm. Well i went out and bought the cheapy actron code reader at Autozone and it when i hooked it up it gave me a code of (32) After replacing the EGR valve last week i cleared the codes and the car ran sweet for about 3 minutes. i am stumped, i would love any advice on this dilema of mine.
Thanks,
Greg
Old Jun 9, 2004 | 07:25 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
I dunno about the car running bad, but I do know that the chances of the code 32 causing it to run bad are like non existent. unless its only throwing the code 32 because your ecu is junk........?
Old Jun 9, 2004 | 12:27 PM
well i am not sure if it is the computer. the code 32 says EGR so i changed that last week and cleared the codes. then a couple days ago the light came on again and said 32 so i was thinking of changing the EGR Solenoid. I have no idea.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
