What kind of header gaskets?
Old Apr 2, 2001 | 09:01 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
What kind of header gaskets are good and last long? Copper seals?
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Apr 2, 2001 | 09:15 PM
perp's Avatar
I have Mr Gasket ultra seals, $18.00 from Jegs. No results yet.
Old Apr 2, 2001 | 09:36 PM
GTAMAN63's Avatar
Joseph Andres,
The Ultra Seals were higly recommend from a local machine shop. I used them and they are holding up well. They tell me they resist "burning out" better than the regular "white" header gaskets. I can not tell you if that is true or not, or if copper is better. Just that they seem to be holding up better than the standard header gaskets I had in terms of durability and seal (ticking).
Barry Izold
89 T/A, GTA
Modified 350/T-5
Old Apr 2, 2001 | 10:23 PM
SUPER-SPORT-CHEVY's Avatar
No copper or paper crap!
Use flow techs dead soft headder gaskets and collector gaskets thier an aluminum/lead mix that fill all the little holes and imperfections well worth the money and thier reuseable!!!!!
Old Apr 2, 2001 | 10:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
For my 89 350 TPI I used Felpro part number 1444. Been a year and a half and 0 problems. Get the stage 8 bolts while your going this.
Old Apr 3, 2001 | 12:07 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I'm also using the aluminum gaskets. I haven't had a problem with them ever since I put them in. The bolts don't even come loose anymore. But before them I went throught two sets of paper gaskets, and even had one header bolt fall out. Go with the aluminum gaskets first, it's cheaper than having to keep buying new paper ones. And then if you still have a problem with the bolts loosening get the stage 8 header bolts.
Old Apr 3, 2001 | 01:22 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
paper gaskets are junk. i use copper with no complaints. SCE pro-copper embossed gaskets are about 30 bucks and i havent blown one yet.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
Jlanz55
Sep 6, 2015 07:28 PM
willyjoejr
Sep 3, 2015 09:26 AM
