lack of power steering at idle
Old Jun 10, 2004 | 03:07 PM
jimmysauter's Avatar
Car: white 1991 z28 w/b;ack racing stripes
Engine: TPI 350
Transmission: world class t5
I bought my 91 z28 last summer and it had tons of stuff done to it. It has a underdrive pulley(sheave or whatever) setup on it and once the car drops below like 1200 rpm or so, the power steering goes away. I was fine driving it like that cause I'd just rev it up in the corners. Then I bumped a curb cause the power steering went away half way through the corner. Is this due to the under drive pulley setup or something else? Does anyone have the stock diameters of the pulleys so I can compare them to mine? Thanks
Old Jun 10, 2004 | 03:59 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
I'm allmost certain it is the underdrive pulley. I would put the stock one from a junk yard on to see if it fixes the problem. Also check the P.S. fluid level and belt tension.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
