gaskets question
Old Jun 10, 2004 | 04:21 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
gaskets question
These are probably stupid questions, so please bear with me. I just got a set of headers, do I need to use any rtv or anything on the gaskets? Also, is there a gasket needed between the engine and tranny?
Old Jun 10, 2004 | 04:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, and no.
Old Jun 10, 2004 | 04:49 PM
ede's Avatar
ede
it's hard to find anything, gasket or sealer to live in the high heat enviroment of headers
Old Jun 10, 2004 | 04:51 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
RTV copper can withstand 700 * of heat. Thats what some of the fourth gen guys are using. This is in conjunction with a real gasket that is.
Old Jun 10, 2004 | 10:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have never used anything when it comes to sealant or whatnot, just a copper gasket from SCE.
Old Jun 11, 2004 | 05:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exactly.... there's no need fro sealer on those, of any kind. Use a good quality gasket; the Fel Pro header hadkets, Mr G Ultra-Seal or their copper ones, the copper or aluminum ones from some of the specialty people, etc.; installt hem properly, make sure the bolts are tight, and re-tighten them after a couple of heat-cool cycles. Sealer won't improve anything, and may even create a failure where there isn't one otherwise.
Old Jun 11, 2004 | 01:09 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Well, you could use Permatex Hylomar or Copper, but you would have to have a reason for it as well as expect to clean up a mess if you ever have to pull it apart again.
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
