air conditioning compresser?
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
My air compressor squeeks like a mother but only when its cold or humid outside. If i drip some oil into where the tip of the green arrow is it will stop for a few seconds. Is that the bearings that are in there? Are they easy to change?
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
[This message has been edited by john5.7 87Iroc (edited November 18, 2000).]
1987 Iroc 350
K&N filters
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
John,
There is a bearing in the clutch hub to allow the sheave to spin freely when the clutch is disengaged. The clutch assembly comes with a new bearing. If you've been oiling this area, the clutch plate itself is probably soaked in oil now, making a new clutch a good holiday gift idea for all your buds. Start dropping hints. With the proper tools, the clutch can be changed with the compressor on the engine, and without evacuating the refrigerant in the system, so the cost should be reasonable.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
Transmission: 4L60e
Axle/Gears: 9 bolt
Originally posted by Vader:
John,
John,
Ok I want to fix this now that I am off school for the next month. You said it is the cluth. I dont know crap about the parts. i was looking around and found these two pictures
Which one of these were you talking about that I should replace? The whole unit on the left or that one on the right?
1987 Iroc 350
K&N filters
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
[This message has been edited by john5.7 87Iroc (edited December 12, 2000).]
Transmission: 4L60e
Axle/Gears: 9 bolt
t
[This message has been edited by john5.7 87Iroc (edited December 13, 2000).]
Dialed_In
Aug 20, 2015 01:45 PM
