MAF Power Relay?? This it?
Old Apr 4, 2001 | 06:24 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
im getting a code 34, thought it would be MAF replaced it. Nope, still running the code. Im also getting a code 32. Would it possibly be the MAF Power Relay? How can i check?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 4, 2001 | 06:43 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Swap the relays, and if the code goes away, then it was the relay. (Most likely your problem). If you still get the same code, then it's the MAF sensor. By the way, what sensor did you replace it with?
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 4, 2001 | 07:34 PM
Ok, ill try that. I replaced it with a new ac delco unit.
1989 Firebird
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bert87
Aug 23, 2015 03:50 PM
