Miniram and AFR 210's
Old Apr 4, 2001 | 09:54 AM
BigBlockJason's Avatar
Car: 1985 Z28
Engine: 502
Does TPIS make a Mini to fit these heads? I know it works with the 190 and 195's, but I dont think I have heard of anyone using the 210's with a Miniram.
Thanks!
BigBlockJason
85 Z28 T-Tops
http://communities.msn.com/JasonsStuff/homepage
Old Apr 4, 2001 | 10:09 AM
89ProchargedROC's Avatar
when you order....you have to tell them you are going to use the AFR 210s and they make the miniram with a higer intake port to fit the heads
Old Apr 4, 2001 | 04:16 PM
Car: 1985 Z28
Engine: 502
Thanks alot boss !
BigBlockJason
85 Z28 T-Tops
Old Apr 4, 2001 | 08:19 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Just a suggestion here!! With ANY tpi (stock, miniram, etc.) the AFR 190's and 195's will give you more torque to put to the ground than the AFR 210's!! Now the Miniram will give you more top end HP and about another 1,000 RPMs BUT you also give up low end torque in exchange!! Now you put Miniram AND AFR 210's on the engine and you're looking at a quite large low end torque loss!! Miniram would be much better with AFR 190's!! Just my opinion from gained knowledge about the AFR heads!!
TX-SleeperC5
Feb 24, 2016 01:34 PM
ULTM8Z
Oct 2, 2015 01:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
randywyatt200
Sep 9, 2015 04:27 PM
