rocker arm ratio sbc 400 (406)
Old Jun 13, 2004 | 11:49 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
talking to a friend that says the small block 400 had a rocker arm ratio of 1.7 - 1 ..... i havnt been able to verify this or prove him wrong ... if hes right im running the wrong rocker arms for my motor ... thanks for the info ... tao
Old Jun 14, 2004 | 12:28 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
As far as I know all Small block chevy's except for LS1's, dont know bout LT1's, came with 1.5"s.
Old Jun 14, 2004 | 12:40 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
1.7 is possible, however, not to many people have done it. In MOST cases, its either going to be 1.5 or 1.6 that people are using. Comp offers a 1.52 ratio as well.
Old Jun 14, 2004 | 01:40 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Its 1.5 for sure....not 1.7...you can fit 1.6 rollers like I have though.
Old Jun 14, 2004 | 06:09 AM
ede's Avatar
ede
400SBC is a 1.5 rocker however other ratios cound be had with aftermarket parts
Old Jun 14, 2004 | 07:50 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
stock, all SBCs had 1.5
Old Jun 14, 2004 | 09:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
1.7 is possible. I've seen it. You use BBC rockers, which are 1.7 ratio. I even have a book that has a diagram that shows exactly what needs to be done (for a machinist to do though) to the heads for it to work.
But thats what all the big racers did before the higher ratio SBC rockers were available... they just modified the heads to use BBC rockers.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
