Two Sensors on Thermostat Housing
Old 06-14-2004, 11:12 AM
sorch60's Avatar
What are the two sensors on the thermostat housing on my 83 TA?
Old 06-14-2004, 11:14 AM
ede
ede's Avatar
WAG temp gauge sender and fan switch
Old 06-14-2004, 11:15 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
One with wires is the temp sensor for the ECM.
One with vaccum lines is a temp sensor for the emissions AIR pump system.
Old 06-14-2004, 11:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The one is for the ECM; however, the other is the thermal vacuum switch for the EFE (heat riser) system. You can see how it hooks up on this diagram; it's called "EFE TVS".
Attached Thumbnails Two Sensors on Thermostat Housing-emissions-hose-routing.jpg
Old 06-14-2004, 11:26 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
my bad. I knew that one of the lines were common with the AIR system. But I guess that was the common source vac.
I will try to do better in the future.
Old 06-14-2004, 03:44 PM
sorch60's Avatar
so i guess i need to keep the one that goes to the ecm, I don't have the heat riser (thing in my pass side manifold) any more.
92firebirdguy
09-01-2016 07:53 AM
dbrochard
10-03-2015 12:43 PM
Bubbajones_ya
09-14-2015 08:38 PM
85Special
09-03-2015 04:21 PM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: Two Sensors on Thermostat Housing
