Sometimes it starts
Old Jun 14, 2004 | 04:08 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Sometimes it starts
Got an 88 Roc and when I drive the car for a while and let it heat up, then let it sit for say 5 minutes or so while off, it sometimes doesn't start. When it doesn't start it does not make a sound, the starter is about 4 months old give or take. I thought it might be the alarm system, but i bypassed the relay and it still does it sometimes. Any ideas welcome.
Old Jun 14, 2004 | 06:06 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Sounds kinda like heat soak. Have you installed headers on your car? If so you may need to install a heat shield for the starter. Also make sure your battery and charging system are in good condition. When my alternator went dead the starter wouldnt even pop the solenoid when it was hot but it would start right up when it was cold.
Old Jun 15, 2004 | 12:11 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Think it might be to blame on the pullies for not charging the battery quite enough? It just gets annoying when you have to get friends to push you down the hill so you can pop the clutch. Oh yea I don't have headers or anything, just what is in my sig.
Old Jun 15, 2004 | 12:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like it needs a starter. I wouldn't futz around with heat shields or any of that crap; it will just return to haunt you.
Old Jun 15, 2004 | 12:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
He should at least hear the starter solenoid clicking. Have you checked any other possiblities such as the clutch start switch.
Old Jun 15, 2004 | 01:17 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
I haven't really looked into anything yet, I think im going to replace the starter today since its a lifetime waranty one. You guys have any idea where the clutch switch is, never had to replace that one yet.
Old Jun 15, 2004 | 01:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's on the back of the clutch pedal.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
