Temp Light - Engine issues (halp!)
Old Mar 20, 2001 | 04:57 PM
Sleeper_In_Seattle's Avatar
Hi, I am hoping to get a few ideas on what the heck could be wrong with my ride... I just had a 350 brought into my 86, but I am now seeing a wierd occurance... I drive her to work in the morning about 15-20 miles away from my home. Not a thing, when I get out from work and head back just as I am getting on the I-5 my temp light comes on... Ack! had this happen for the last 3 days... I pull off into a rest area and check my engine levels... Rad is topped off nicely and the overflow is running a bit above the HOT level... This is not happening on the ride in and I cannot figure out what the problem is... It is about the same street and freeway driving both ways... so why does the damn light come on... I notice if I keep her at around 55-60 and do not make sudden accelerations the temp light dims out... When I check her at home things look ok.. I am bringing her into my mechanic on the weekend (as this is out of my scope of knowledge) to check her out but want a couple ideas to toss his way before I have him look at it... Thanks for any info you guys can pass along. I don't want her in the shop for too long
Dark Grey 86 V8 305
First Mod:
Upgraded to a 350
Future Mods:
Too many to list
Old Mar 20, 2001 | 05:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So... is it in fact overneating? It sounds to me lke it isn't, especially if it's possible to open the rad cap while this is going on.
When you turn the key to the "Start" position, it's supposed to ground the light circuit, to be a bulb test. i.e., the bulb is supposed to light when in Start. Is there anything flaky about your ignition switch?
More than likely though, you just need a new temp sending unit.
ICON Motorsports
Old Mar 20, 2001 | 05:50 PM
Ignition is a bit flacky, in that it sticks a bit... Temp unit could be something to check... I have to double check the rad on the when I get in tonight, but she is usually openable the last few times I check her... Any other ideas?
Dark Grey 86 V8 305
First Mod:
Upgraded to a 350
Future Mods:
Too many to list
[This message has been edited by Sleeper_In_Seattle (edited March 20, 2001).]
Old Apr 3, 2001 | 04:08 PM
T/A Man's Avatar
Check to see if your radiator has any crap blocking it. Also check to make sure your front air dam under the radiator is intact. If it is broken replace it. See "Front Air Dam?? topic" Good luck
Old Apr 5, 2001 | 11:15 AM
Box of Rocks's Avatar
<font face="Verdana, Arial" size="2">Originally posted by T/A Man:
Check to see if your radiator has any crap blocking it. Also check to make sure your front air dam under the radiator is intact. If it is broken replace it. See "Front Air Dam?? topic" Good luck</font>
Also,
Thermostats are known to often act like victims of Voodoo mechanical persuasion: I've had a slew of them do the "overheats,but only sometimes" routine.
Change it, it's cheap and will barf out eventually anyway.......at the worst possible time. Good luck.
OBTW - the tips mentioned by T/A Man above were worth quoting, as many 3rg genners know.
BOR
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
