What order to do timing, tps, iac??
Old Apr 5, 2001 | 03:03 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Since changing the timing will affect idle rpm, how should I go about precisely tuning the car? It's a tpi iroc lb9. Should I do IAC and TPS then timing or the other way around? It just seems like adjusting the timing can change the rpm which will make me want to reset min. air which will make me want to reset the tps...you get the picture. Thanks for any info...
Old Apr 5, 2001 | 08:21 AM
speedlvr's Avatar
Just last night I did that. I set IAC, TPS and then set the timing. Worked out well.
Old Apr 5, 2001 | 08:54 AM
jobryan26's Avatar
<font face="Verdana, Arial" size="2">Originally posted by speedlvr:
Just last night I did that. I set IAC, TPS and then set the timing. Worked out well. </font>
Did you notice any differance?
'87 Trans Am:
(Engine)
305 TPI
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Kenwood Excelon
Old Apr 5, 2001 | 01:18 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Ok, did the timing change your idle rpm? I have my IAC and tps set right and I'm just messing with timing - the manual that came with the light says that timing changes can affect rpm so it seems like we're dealing with a loop of cause&effect. Thanks for the reply.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
