are roller rockers noiser than stamped rockers?
Old Apr 5, 2001 | 11:06 AM
bad camaro RS's Avatar
my roller rockers kinda of tick or chatter is this normal i had 1.6 crane rockers they were same way i now have harland sharp 1.65 rr and they to are what i consider noisy thanks later
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 5, 2001 | 11:39 AM
Biochem's Avatar
Car: 2002 SOM z28
Yes...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 5, 2001 | 02:00 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
How do you like those 1.65's?? I was thinking about getting those. I have the Harland Sharp 1.5s right now and wanted to bump the lift up a bit.
'89 Formula 383 TPI
Old Apr 5, 2001 | 02:37 PM
i like em not i didnt notice much but i went from 1.6 to 1.65 but every little bit helps right? later
4" mufflex system
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
