Reading Service Engine Codes
Old Jun 16, 2004 | 12:05 AM
89IROCCVRT's Avatar
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
Ok, I understand the whole..stick a wire in the troubleshooting port in the car, but how do you read the code itself? I understand the beginning sequence of flashes, but when light flashes the actual code, what does it mean? I received 3 short flashes, then a pause, then 4 more flashes, pause, 3 short, so on and so forth before the beginning sequence flashed again. So how do I read those flashes to figure out what is wrong with the engine.....Thanks
Old Jun 16, 2004 | 01:27 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Reading Service Engine Codes
First set of flashes will be the number twelve. One short flash and then two short flashes. It should do that 3 times. The 3 short flashes with a pause and then 4 short flashes means number 34. Code 34. It will then keep flashing until there are no more codes and just repeat itself. 2 short flashes and then pause with 5 short flashes would be 25 and so on...
Old Jun 16, 2004 | 09:15 AM
89IROCCVRT's Avatar
ok i understand now, thanks for the help
Vintageracer
Jan 10, 2020 05:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
