Gas Gauge; easy fix?
Old Apr 4, 2001 | 07:49 PM
Eric L's Avatar
I need to know if this will be an easy fix or really involved. My gas gauge is stuck on E since i bought the car two weeks ago. I would like to know what i should check to get this to work.
Old Apr 4, 2001 | 08:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's hard to tell. It might be something as simple as a disconnected wire. The gauge itself might be bad. Or, the sending unit in the tank could be bad, which is one of the ultimate PITA things on these cars.
Take a look at the wires around the tank first; make sure the ground one is hooked up from the tank to the chassis.
Do all the other gauges work? If not, check the gauge fuse.
ICON Motorsports
Old Apr 5, 2001 | 08:54 PM
Eric L's Avatar
All the other gauges work and i checked the fuse.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Dkelz313
Apr 7, 2016 10:38 PM
BurlyChev
Aug 16, 2015 09:08 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
