How do I disconnect the f%$#%$## knock sensor?!
Old Apr 5, 2001 | 09:06 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Alright I'm under the car trying to disconnect the knock sensor, fan switch, and starter wires (89 tpi iroc). I disconnected the sensor highest up on the engine which I believe is the fan switch (they're both single wire connectors) but the lower one with the white plastic shield is giving me fits. Is this the knock sensor? How the he!! do you get it off? I pulled up on some tabs and swung one part of the connector away but it seemed to have no effect. I didn't want to pull too hard.....please help and advice is appreciated!
Old Apr 5, 2001 | 10:46 PM
93ND500's Avatar
There should be two raised areas 180* apart on the connector. Squeeze them together and pull. This should let it come off. That's how it works on my harness.
Old Apr 5, 2001 | 10:54 PM
Ringmaster72's Avatar
Car: 1989 IROC
IROCK, what color is your knock sensor wire and what color is the fan switch(the one in the cylinder head) Thanks, Tim
Old Apr 5, 2001 | 11:12 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
The knock is a white wire. The fan switch is high up near the plugs and the knock is at the base of the block.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
