Oil Pumps
Old Apr 5, 2001 | 12:39 PM
Changa2's Avatar
Oil Pumps
I'm building a 400+ HP 383 (all Ductile Crank assembly) and need an opinion on Oil Pumps.
Which type is better for the engine: Std. Volume or Hi-Volume? And secondly are the high dollar pumps necessary?
I'll be using a 7qt. pan that will require a slightly longer pick-up.
I'll be running mostly Street but occaisional Bracket.
[This message has been edited by Changa2 (edited April 05, 2001).]
Old Apr 5, 2001 | 03:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you aren't doing anything to the bearings that increases the engine's internal oil consumption, like grooving the top half of all the mains and cross-drilling the crank and all that sort of thing, then the std volume is fine. High pressure is a good thing though, use the Mr Gasket part # 26 spring which will raise the pressure to 55-60 psi. Use the longer pickup screen if necessary. The Melling pump is M55, the screen is 55S, 55S1, 55S2, or 55S3. Just look at them and pick the one that fits your pan the best.
ICON Motorsports
Old Apr 5, 2001 | 04:42 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Yea, what rb said. You really don't need to do much to the oiling system of SBs in most case. Get the clearances right and ensure good oil drainback and control. Everything else manages itself in most cases. Don't skimp on the oilpump drive shaft.
Old Apr 5, 2001 | 07:14 PM
ede's Avatar
ede
agree melling m55 with the mr gasket #26 spring
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 5, 2001 | 11:38 PM
Changa2's Avatar
Thanks Guys. The good old second opinion is invaluable.
Old Apr 6, 2001 | 07:45 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
one thing that is often overlooked and can be the most important (and I almost forgot about), is the distance from the pickup to the bottom of the pan. Shoot for 3/8 inch to 1/2 inch from the bottom. And don't try to cut corners. If you can, find a bolt-on pickup that is made for the pan you intend to use.
[This message has been edited by jcb999 (edited April 06, 2001).]
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
