Car makes more sound than it runs ...WHY ?
Old Jun 18, 2004 | 09:27 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Car makes more noise than it runs,why ?
Hi all,well i ve seen this case oftem and im not sure
why its caused.
I was testing a 84 Z28 Automatic Transmission,305
and i can really say that the car sounds more than it runs
i mean,you accelerate and:
1 It doesn't spin the wheels and can't do burn out
2 When you start driving the car's response is poor
and slow at the beggining but when you are cruising at
45 MPH or more you press the gas and you can feel it accelerating more.
The engine is smooth and you can feel it grow on RPM faster so i discard the engine plus has a real nice sound,i think this can be a tranny problem or a Torque converter problem.
The cars runs real nice but just for cruise,you can't start with burnouts or race it.
You can feel the car makin more noise than it runs,ive seen other cars at the same RPMS acceleranting way faster and with the same engines and trannys !
What you think ?
Thanx !
Old Jun 18, 2004 | 09:43 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
"You can feel the car makin more noise than it runs"
I will assume by this you mean the cars engine RPMS increase but the car is not responding as much as it should be to increased RPM's. My first guess would be a slipping tranny when this happens.
Also you shouldn't expect much if any burnout with a V6, 3500lbs and decent traction setup of these cars.
Old Jun 18, 2004 | 09:49 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
OM, I think it's a 305 car, and I'll second a tranny issue. Could be something as simple as low fluid. Start looking and see if anything is apparently wrong.
Old Jun 18, 2004 | 09:56 AM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
I'd start with changing the fluid and running some seafoam thru it to clean out the varnishing in the valve body
Old Jun 18, 2004 | 10:03 AM
Calderone's Avatar
Car: 87 Vette
Thnx
we changed fluid
yeah its a 305 V8
i dont know ...i think its the converter and/or tranny
"I will assume by this you mean the cars engine RPMS increase but the car is not responding as much as it should be to increased RPM's."
YES EXACTLY !
Old Jun 18, 2004 | 10:05 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
His sig says 83SE with 173CID 2.8 V6
My bad though I see where he said 305 in his post the broken English apparantly was to much for me to read thouroughly this morning.
midge54
Dec 27, 2019 04:14 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
Sherpajames
Aug 7, 2015 06:56 PM
