flexplate question
Old Jun 18, 2004 | 08:03 PM
90_WS6_Formula's Avatar
Car: 91 Z28
flexplate question
if you go from a '90 block to a '83 block.... will you have to use a different flexplate?
Old Jun 18, 2004 | 09:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes
Old Jun 19, 2004 | 01:52 PM
Car: 91 Z28
would the '83 flexplate work here?
Old Jun 19, 2004 | 04:10 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
no. the two flexplates "do not interchange" and therefore, you'll need the two piece RMS flexplate.
Old Jun 19, 2004 | 09:27 PM
Car: 91 Z28
can you elaborate?
Old Jun 19, 2004 | 09:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm guessing you're putting the 83 motor into the 90 car....
The 83 flex plate may work with the 83 block, if it's the right diameter for your starter. If it's the other diameter than what your starter is for, you'll need another starter.
Old Jun 19, 2004 | 09:38 PM
Car: 91 Z28
you're right on the money, RB83L69!! What do they measure starters by? a certain number of teeth?
Old Jun 19, 2004 | 09:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You just have to look at them and identify them.
The one for the 153-tooth setup is smaller than the other, and the motor lead sticks through the case in the smaller part of the case, right near the brush cover, and the bolts are in line across the back of the block. The starter for the 168-tooth stuff is larger, the motor lead comes out of the larger part of the case before it necks down to meet the brush cover plate, and the bolts are in a staggered pattern.
If it was my car, I'd probably want the smaller setup; the starter is a weenie POS, but it gives 5/8" more header clearance. The weenie aspect you can fix, with an aftermarket starter.
Old Jun 20, 2004 | 12:36 AM
Car: 91 Z28
It seems I have the weenie 153-tooth setup. In theory I should get a 153 tooth flexplate for the 83 block?
I should have kept that L98 block
Old Jun 20, 2004 | 02:03 AM
Car: 1982 Trans Am
Engine: 383 chevy
ok... i just realized someting: I should not tryhelping anyone when I'm on my meds. (painkillers/muscle relaxers) disregard anything i said/say, until my back gets beter. (i hurt my back which is why i'm on narcotics.) anyhoo, good luck with your project.
Old Jun 20, 2004 | 05:01 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
There are different part numbers for two piece and one piece rear main seal flexplates. Don't know if there is a difference, but I'd stick to what block I have.
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
