Change from 22# to 24#, really requires prom
Old Apr 6, 2001 | 02:52 PM
KW87GTA's Avatar
If I were to change from the stock 22# injectors to say 24# injectors, would it really require a prom change? Could I get away with not changing since it's such a small change? What would happen if I don't change? Thanks very much.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Apr 6, 2001 | 04:31 PM
snakeskinner's Avatar
22-24 really wouldn't be all that much of a gain but your car should have 19# injectors from the factory. I'm not positive on the later 350 cars but I know 87 was supposed to have 19#. the 92-93 LT1's had 22 and 94+ had 24's.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
jer4251
Sep 1, 2015 09:04 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
