Flywheel help needed -- GM part #s
Old Apr 6, 2001 | 04:52 PM
Maverick13's Avatar
Long story short, the Formula needs a new flywheel. Normally I'd just call up the GM parts dealer and order a new one, but it appears that it's not so simple now that I've installed the Tremec 3550/TKO, as GM doesn't list a flywheel for that application.
I called up Fortes and they said I could use the "stock 350 flywheel", but GM has 3 of those (t5, t56, and ls1?). Could someone please enlighten me as to which flywheel to use. A part # would help immensely. Thank you.
Maverick
1989 Formula 350 TPI
5spd Tremec 3550/TKO
several suspension mods
Old Apr 6, 2001 | 05:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
2 things:
1. You can get a vastly superior flywheel to a GM one (steel vs. cast iron) in the aftermarket, usually for the same or less money.
2. What flywheel did you build it with? It would seem that you should replace it with the same thing.
ICON Motorsports
Old Apr 6, 2001 | 06:01 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
There are three different flywheels which all have the same outside diameter of 12¾" and 153 teeth, which is what you need.
1)GM p/n 14085720, Lightweight nodular iron flywheel for two piece crank seal. Will work with a clutch diameter of 10.4" only. Crank flange bolt pattern is 3.58". Block year = 1955-85.
2)GM p/n 14088646, Lightweight nodular iron flywheel for one piece crank seal. Will work with a clutch diameter of 10.4" OR 11.0". Crank flange bolt pattern is 3.0". Block year = 1986-UP.
3)GM p/n 14088650, Standard weight flywheel for one piece crank seal. Will work with a clutch diameter of 10.4" only. Crank flange bolt pattern is 3.0". Block year = 1986-UP
So you're looking at your choice of either 2 or 3, unless you have an older block in there.
[This message has been edited by TunedPort350 (edited April 06, 2001).]
Old Apr 6, 2001 | 06:44 PM
Maverick13's Avatar
We just used the stock flywheel from my 305 (did a 350 swap at same time as Tremec). For a clutch I'm using Centerforce Dual Friction. The block is an 88 or 89. There's a new cam in it too (RV) if that makes a difference.
So I should probably get the lightweight? Or should I go aftermarket?
Maverick
Old Nov 13, 2005 | 07:38 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
back from the dead
HOW ABOUT this flywheel.
P/N 14088671
This I believe to be a 1 piece RMS variety. I am too lazy to count teeth, and google is NO help.
later
IROCZ1989
Jan 24, 2016 03:55 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
