140 AMP alternator and 16 volt batteries?
Old Apr 6, 2001 | 02:41 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Can we just swap in a 140 amp B4C alternator into our cars without any other mods? Also,
same question for a 16 volt battery?
Anyone done these mods lately?
Thanks!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
Old Apr 6, 2001 | 09:24 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I thought the B4C was 120 AMP like the TTA.
"Education is the art of making man ethical.
-George Hegel
Old Apr 7, 2001 | 12:08 PM
89ProchargedROC's Avatar
you can swap in the alternator w/o a problem but not the battery. there is a special alternator you have to run and special wiring.
Old Apr 7, 2001 | 02:48 PM
camaroguy99's Avatar
like the previous posts the alt. won't be a problem but the 16 volt battery will. Becuase of this, your alt. charges a normal 12 volt battery at about 13-14 volts. without the alt having a higher voltage the battery won't charge. You would mostly likely have to get an alt. with an adjustable regulator (really fun with a system in your car ) or a regulator that is set at like 17-18 volts. One thing to watch out for is that you might fry your on-board electronics if you have a voltage above like 17-18.
Hotrodboba400
Dec 10, 2019 07:07 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
