replaced fuel pump. now whats wrong?
1 Post
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
this on the 82 with TPI
replaced the pump.. and its running. im getting 45 psi at the rail with key on but engine off... when i go to start the car it drops to below 30 psi and car runs for maybe 2-3 seconds then dies.... is there maybe air in the line? maybe i have a kinked line?
ive been trying to get it to stay running for maybe 15 mins and it still trys to run then dies... i dont know what else to do
when i have the key on but engine off i hear gurgling at the fuel rail.. you think maybe my fuel pressure regulator went out? CAN they go out? lol
i just wanna go throw the car off a cliff
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What happens if you keep the pedal pressed a bit? Does it stay running? Or does it die no matter what?
Are there any codes? What is the idle speed at (if you can get it to idle)?
1 Post
Engine: LT1/350 TPI
if i press the pedal at all it dies faster. its was throwing codes when i had it running. but none that kept the check engine light on. im really thinking its the fuel pressure regulator..
1 Post
Car: 91 RS
Engine: 305 Tbi (L03)
May be a plugged fuel filter. Kinked line is also a possiblity. Alot of times a pressure regulator will have the diaphram break but they dont hold when that happens.
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
92camaroJoe
08-13-2015 06:07 AM
