WIPER MOTOR?
Old Apr 5, 2001 | 07:48 AM
BLACK2000SS's Avatar
WIPER MOTOR?
On my son's 89 Iroc the wipers work but they won't shut off and the delay doesn't work either. There are a couple ways to get them to stop one is to shut off the car and then turn it back on, the wipers will wipe a few more times then shut off. Another is to unplug the power to the motor itself and again it will wipe a few more times and shut off. Last is to unplug the connections going to the wiper motor module and again it will wipe a few more times and then shut off. Any help would be appreciated.
Old Apr 5, 2001 | 08:34 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
On the wiper motor itself, there is a black cover. Under this cover is a circuit board that controls all of these functions. They frequently go out. Go to the junk yard and pick up a whole motor. It'll probably cost you around $25. They are pretty easy to change. If that doesn't fix your problem, it may be in the stalk. But since it will shut off after shutting the car off and restarting it, I would look at the motor itself first. Good luck.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 5, 2001 | 10:14 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Mine do the same thing. After disassembling the entire motor unit, I figured out why. There is a platic wheel with teeth on it, which a metal arm is supposed to catch. Well, the plastic wears down, the arm doesnt catch the wheel, the wipers stay on. A new unit is $70 from Autozone, thats what im gonna buy soon. I got one from the junk yard for $20 off an old 83 caddy. It works okay, but the pump for the fluid is broken. BTW, I don't recommend pulling the motor assembly apart; Its a pain in the a$$.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old Apr 7, 2001 | 05:45 PM
Well it's fixed. Went to the junk yard and got a whole new(used) motor for $25.00 bucks.Must of been something in the motor assembly. I tried the outer black cover first, the delay worked then but it still wouldn't shut off. Thanks guys for your help. I am glad it wasn't the switch on the column. That looks like a pain to change.
Frozer!!!
Jan 19, 2024 04:55 PM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
eddie jr
Aug 25, 2015 06:52 PM
slade5612
Aug 11, 2015 07:19 PM
