What size harmonic balancer do I have? PLEASE HURRY.........
Old Apr 7, 2001 | 02:49 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I want to change out my distributor today and I need to know what size it is to make a timing tape. I know it's right around 6 inches, but I need to know exactly. What sizes do they make that are right around 6 inches? It's an 89 350.
Also, do I put blue silicone on both sides of the gasket, or just on the top part where it contacts the distributor? Thanks.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box.
Old Apr 7, 2001 | 02:58 PM
Guest
Guest
Posts: n/a
I wont answer what size, because I'm not positive. So I'll let someone else catch that one.
Dont put ANY sealer on the distributor gasket whatsoever. Thats what the gasket is for.
Old Apr 7, 2001 | 03:12 PM
ede's Avatar
ede
6 5/8" i think
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 7, 2001 | 03:30 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
1000% sure it is 6-3/4" Diameter. Only other size for an SBC would be 8", but that was for the '60s-'70s muscle cars (hi-po engines) and maybe HD trucks.
George P. Lara
1984 "L69 A4"
Soon to be 357 T5
1994 LT1 M6
SCCA, SCFB, SC3GFB
Old Apr 7, 2001 | 07:29 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
where do I hook up the vaccuum advance line to the carb for the vaccuum advance on the distributor? I have a holley 650, mech secondaries, spreadbore.
1986 CAMARO Z28 ->
1987 TRANS AM ->
Old Apr 7, 2001 | 11:27 PM
82z's Avatar
82z
Why don't you just measure it?
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
Linson
Sep 21, 2015 01:08 PM
Magman
Sep 13, 2015 12:14 AM
m00n420
Sep 11, 2015 02:39 PM
