Fuel System Question
Old Jun 22, 2004 | 07:53 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
I have an 84 Z28 with the L69 engine, i just bought an $80 Edelbrock fuel pump, part #1721 and it fits the engine, but it doesnt fit the compartment, do you guys know of any good aftermarket fuel pumps that will fit in my engine compartment. Also i noticed that the car has two fuel lines both going into the stock fuel pump, but one of the inlets are big and one of them are small, my mechanic said that the smaller one is an overflow line so if the pump starts pumping too much fuel it will send it back to the tank, is this true? because the edelbrock pump has one inlet and one outlet so what would i do with the overflow line, plug it? and if so what would happen if the pump started pumping too much fuel, where would it go?????
Old Jun 22, 2004 | 09:18 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The smaller line is used to return excess fuel to the tank. If the new fuel pump doesnt have provisions for a return line, it isn't needed. The pump will only pull as much fuel as it needs. You could just plug up the return line. One downside to a returnless system is that they are more likly to vapor lock on hot days.
Old Jun 22, 2004 | 09:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The stock pump is perfectly adequate. I'd just go to the store and get a $12 one and be done with it. It'll move enough fuel for at least 400 HP.
Old Jun 22, 2004 | 09:42 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
i know your right, but i rele want to get a nice edelbrock or holly fuel pump, and i want to keep the system as stock as possible so do you know of any fuel pump that has the inlet and overflow line?
Old Jun 22, 2004 | 09:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A stock one.
You don't need a "nice" one. It's a step backwards. It will do more harm than good. Just get a stock one, it's perfectly adequate, more than you need.
Some things, the stock ones are absolute crap; some things, they're the best you can get. In this case, especially if you don't want to be modifying lines and all that, stock is best.
Old Jun 22, 2004 | 09:48 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
thanks, i guess i will go with a new stock one, just one more question, the edelbrock says it produces 6psi, would that be too much and if so how would that harm the car? and what is the psi of a stock pump
Old Jun 22, 2004 | 09:53 PM
dankhound's Avatar
Car: 91 RS
6 psi will work. At around 8 psi the needle in the float bowl wont seat and youll run rich. The stock pump was probably in the 5-6 psi range.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
redmaroz
Aug 16, 2015 11:40 PM
